Mach 1 cams
Mach 1 cams
I have a 96 gt and I did a 4v swap so I have a 97 cobra engine. I was on ebay and I found some 4v cams from a mach 1 for $60 so I bought them. Should I use these cams or my current 4v cams? I have been thinking of porting and polishing my heads soon anyway and I obviously can not afford 1500 for just new cams lol.
RE: Mach 1 cams
The mach 1 cams won't give you any additional power over what you already have. They are setup to give a little more low end torque than the Cobra cams IIRC. Cam installs on a 4 valve are a b@tch! If you pay someone to do it, it will cost way more than its worth to use those cams.
RE: Mach 1 cams
ORIGINAL: Ehmark
RE: Mach 1 cams
The Mach cams will give you moretorque down low. They are definetaly better than the ones you have. I would change them. It's one of the thingsthat help put Machs a tiny bit ahead of the 01 SVTs.
RE: Mach 1 cams
ORIGINAL: Stone629
RE: Mach 1 cams
ORIGINAL: Sunadaime
Wait? do you have a 96 gt w/ 4v swap or do you have a 97 cobra? your year and trim dont change because you made the head swap o.O
wheres the confusion?? [sm=dontgetit.gif]
