Anyone recognise these plugs??
Hi guys,
Been having a bit of trouble recently with vibrations at idle and the odd rattle fromt the underside on my '98 GT auto, so I decided have a look underneath and found these plugs just sort of hangin there, what do you think?
http://i130.photobucket.com/albums/p...0/IMG_1884.jpg
http://i130.photobucket.com/albums/p...0/IMG_1883.jpg
one of the images is just above the exhaust and the other is near the front, thats the front left wheel you see.
Cheers
Geo1400
Cheers
Geo1400
RE: Anyone recognise these plugs??
So should they be hangin or should they be plugged into something??
The one up front is on it's own and attached to a bracket which isn't attached to anything, hence the hangin. And the one with the 2 plugs is just around the middle of the car, I think you can see the prop shaft coming out the trans just behind the plugs.
Thanks for your responce, Geo1400
No CEL on and it does work cause it comes on with ignition. I'm guessing the mid pipe is stock, possibly even the original.
If the O2 sensors aren't plugged in how would that affect the performance/drive of the car?
