I believe I have a coolant leak
Last night I had my car running and there was a bunch of steam coming out over/under the headlights, I could smell the coolant, now my question is, since it was too dark for me to see anything last night. Where would be the first places I should check for leaks, I will of course look at all the hoses and everything but there was nothing at all dripping on to the ground so I don't think the leak is too bad.
99 GT
99 GT
RE: I believe I have a coolant leak
You prob. have the inatke manifold with the plastic coolant crossover. it happend to me a year ago. Youll need to replace it with a new pi intake manifold with an aluminum crossover, im not sure but i think you can get a replacement from the dealership.
Actually I replaced that in May
The coolant was low, I just let the car run for long enough to get hot and send coolant through the engine but no steam or leaks today...
Why would it be doing it last night but not today, I was not driving hard when it happened or anything and the bottle was almost to the bottom so it leaked out a good bit at some point but I can't find any wet areas, nothing on the ground.. no steam, I am confused!
If you cannot find an external leak,a used oil analysis from a third party lab such as Blackstone will tell you if you have an internal leak. The culprit at that point would most likely be head gasket or intake.
Ok I took a drive and it started again, there is a small pool of coolant under the intake manifold... not near as much as when I had to replace it, but I can't see this one being bad especially this soon...
I guess I will have to pull it all apart and see if maybe the gasket is leaking or a hose cracked or something... damn this car to hell!
