piston help
Old Dec 22, 2007 | 11:49 PM
mustangman36578's Avatar
mustangman36578
Default piston help
i will be rebuilding me engine this winter and im going to go with all forged internals. i plan on supercharging (centrifical probably vortech) and running nitrous too but i dont plan on doin those until later when i have more money so for now it will be N/A. how deep of a dished piston should i get that will still be deep enough for when i do go to superchargeit and run nitrous but would still have high enough compression on a N/A motor?
i also plan on porting and polishing the heads and possibly bigger valves and 75mm polished tb.
Old Dec 23, 2007 | 10:44 AM
contentsunderpressur's Avatar
Default RE: piston help
If you go with a -15cc dish Diamond piston it'll put your compression ratio at 9.4. You won't be able to run much more than 12 lbs of boost without race gas but you can spray it with nitrous. My setup is -15cc dish Diamond pistons, Procharger with a 3.2 pulley making 11 lbs of boost, NX nitrous system with a stand alone fuel system for the nitrous running a 75 shot. This combo put 506 hp to the wheels.
Old Dec 23, 2007 | 11:13 AM
10inch Terror's Avatar
10inch Terror
Yep, I agree. Anything in the 15-19cc area is what you should be aiming for. Diamons makes a 15 and 19cc, CP makes a 17cc and Manley makes an 18cc.
Old Dec 23, 2007 | 11:25 AM
ORIGINAL: 10inch Terror
Wow dude!!! That's one bad *** ride you got there!!!
Old Dec 23, 2007 | 11:30 AM
mustangman36578
how do probe pistons and rods hold up? im looking at a forged rotational from stage 3 motorsports for $1,500. i would like to get diamond but im on a budget.
Old Dec 23, 2007 | 11:34 AM
I've heard a lot of good things about Probe. I think you'll be ok going with it.
Old Dec 24, 2007 | 11:13 AM
10inch Terror
ORIGINAL: contentsunderpressur
Thanks!
Old Dec 24, 2007 | 11:15 AM
10inch Terror
They are certainly not high end stuff but as long as they are not pushed hard, they should be ok.
poke68
Dec 16, 2025 03:36 PM
uberstang1
Dec 7, 2017 07:10 AM
uberstang1
Sep 20, 2015 06:42 PM
degner122
Sep 16, 2015 07:09 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
