Motor
Old Dec 24, 2007 | 11:29 PM
TayGt's Avatar
TayGt
Default Motor
Would it be better you to mod my 2v or swap in a 4v? IF i go the 4v way how hard woudl it be toswap a 4v in? LIke wiring fit ment and all.
Old Dec 24, 2007 | 11:33 PM
mustangman36578's Avatar
mustangman36578
Default RE: Motor
i think the computer just needs to be reflashed.
Old Dec 24, 2007 | 11:35 PM
TayGt's Avatar
TayGt
Default RE: Motor
well does it just bolt up? or do i have to cut and weld it to fit? Is It worth the work?
Old Dec 24, 2007 | 11:47 PM
mustangman36578
Default RE: Motor
i think it has the same motor mounts and everything. i havent done the swap but from what ive heard its an easy swap to do because its the same block and drops right in.you might want to hear it from one of the guys on here who have done it though. i know there are quite a few people who have done that swap.
Old Dec 25, 2007 | 12:48 PM
RJW's Avatar
RJW
Default RE: Motor
I've thought about it a time or two and did some reading on it last night. If you go with any number of 4v's you will need to make a decision on what you're going to do with your computer. If you go with the 4v harness and ECU, you have to find a way to wire it all up. You have to change the fuel system and tank, you have to change out the guage cluster, and you have to make some other modifications pertaining to the harness. If you stick with the 2v ECU and harness, you can get hook it up, but you will need to dyno tune the new set-up.
I could very well be mistaken, I'm only going from a single thread I remember seeing.
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Drastang
Sep 30, 2015 03:48 AM
logan409
Sep 26, 2015 07:43 PM
