Difference between 01 cobra motor and 03
Other than the supercharger and the fact that it has forged interntals.
Are the heads different? Is there any reason why you couldnt take the charger off a 03 and slap it on a 01 is basically what I want to know
RE: Difference between 01 cobra motor and 03
The heads are different. The '03/04's pistons have more of a dish. If you did put the blower on the '01 heads, you may not be able to run as much boost and/or timingas an '03 motor because the compression will be higher. I think the '03's had 8.5:1 and the '01's had 9.85:1.
the ports are the only difference but it will still bolt up and work fine, you will be producing higher numbers due to the higher CR though. 9.85:1 still isnt too bad of a number boost wise, you will just have to have a little more timing pulled when it gets tuned.
Ok well heres what a buddy said and I told him I think you can still bolt it on
cuz like the fords... i bought a DOHC for my stang and the heads are different so i cant use the heads to bolt the eaton supercharger lower intake on. I was just kinda thinking about that and then i thought about the gibbs trucks having the superchargers and it would be kinda sweet to find a wrecked on and get the stuff of it to do mine. But like i said it was just a thought. Im bout to BD mine and get new wheels after that i want to supercharge it...
Eaton Supercharger
manifold
wiring harness with fuel rail and injectors
heat exchanger
intercooler
TB and plenum
upper tensionor bracket
lower pulley
Intercooler piping, pump and tank
alternator and bracket
'03 cobra front timing cover
03 cobra harmonic balancer
03 cobra tank and pump
intlet tube and maf
tune
alternator and 2 brackets
powersteering lines need to be relocated
powersteering pulley
[hr]
manifold
heat exchanger
intercooler
TB and plenum
lower pulley
intlet tube and maf
tune
[hr]
