TB+Plenum question
Old Jan 4, 2008 | 12:33 PM
70 MACH I's Avatar
70 MACH I
Default RE: TB+Plenum question
GOOD STUFF, I HAVE ONE ON MY CAR!
JOHN
Old Jan 4, 2008 | 01:41 PM
Ecstasy's Avatar
Ecstasy
professional products are a good company, i would get it, its about the chepeast your going to find that setup for.
Old Jan 4, 2008 | 02:41 PM
Smiths01GT's Avatar
Smiths01GT
Thanks everyone for the help! I bought the Polished set up today
Old Jan 4, 2008 | 04:18 PM
DrDeaths01GT's Avatar
DrDeaths01GT
Man, that candy apple red is sweet, I thought a 75mm on a stock motor was too much??
Mabye I heard wrong, I thought 70 was the limit for a stocker.
Old Jan 4, 2008 | 04:36 PM
Ecstasy's Avatar
Ecstasy
75mm will probably hurt you more then help you on a stock motor unless you do some headwork, you still have to upgrade the intake though.
Old Jan 4, 2008 | 05:24 PM
Smiths01GT's Avatar
Smiths01GT
ORIGINAL: Ecstasy
Ecstasy. I spoke with the guys at Dynamic Racing Products where I bought the tb/plenum. They said that everything is compatible with a stock motor. Which one is it? lol I already ordered the damn thing [:@]
Old Jan 4, 2008 | 05:34 PM
Ecstasy's Avatar
Ecstasy
im not saying its not compatiable, but its not going to really do you any justice without a cold air kit & doing some head work, your not going to reak the benefits. ive seen it hurt some stock mustangs & ive seen it help some. really all depends on the mods, aftermarket mid pipe, gears, catback, cold air kit, ud pulleys itll help you out, if your stock itll hurt you.
Old Jan 4, 2008 | 05:38 PM
scfd524's Avatar
scfd524
ORIGINAL: Ecstasy
I guess I don't understand how an increase in airflow is going to hurt you in anyway possible. Granted without some other mods you're not going to be able to use the full capacity of the 75mm but I don't get how it could have a negative affect on the performance.
Old Jan 4, 2008 | 05:44 PM
tim2002gt's Avatar
tim2002gt
^Maybe it has to do with the flow velocity. IDK! I don't see it really hurting you either. I had other bolt-on's when I added the tb and plenum so I can't say it would or would not have hurt me if I were completely stock.
Old Jan 4, 2008 | 06:17 PM
STANG0446's Avatar
STANG0446
i only had a k&n filter charger kit, high flow x pipe, and pulleys when iadded my accufab 75mm tb and plenum and i saw increase in top end more than anything but did not hurt me in the least.caution after the install my iac went out. i hear it happens, but i think you made a wise move. jmo
