Speedo Recalc
Cheapest way I can think of is to get a speed calibrator from AM.
http://www.americanmuscle.com/speed-...tor-94-04.html
About 100 bucks with the discount code. Other than that, don't know what to tell you. You could get a dyno tune if you want to spend more money. It is more expensive but your car will probably run better, and with the dyno tune the tuner will be able to adjust your speedo to read the proper MPH.
Cheapest = Speed Calibrator
Easiest to calibrate = Handheld tuner
If you get a handheld tuner,the company you buy it from will give you a couple tunes for your specific carand they will accomodate your gears into all of the tunes. The speed calibrators need to have wires spliced, if I'm not mistaken. If you were planning on getting the tuner at any time in the future, you might as well go ahead and get it now.
