my KB 14psi + small shot??
as of now im runnin 10psi off my 2.1KB and was wonderin after forged motor and all of that and bump it up to 14psi and if im still not happy could i run a small shot..? I know others run s/c or t/c with nitrous but does it matter if the s/c is already maxed out?? like will that matter or since there 2 diff things it will be fine?
RE: my KB 14psi + small shot??
Kenne bell doesn't recommend nitrous because of the materials used in coating the rotors. I don't rememer if they say only use wet or dry kits, but your best bet is to talk to KB. They will be able to give you the facts.
ORIGINAL: sstang
I would think if anything, you would use a wet system after the blower (if the rotor coating thing is true). But as the others said, call KB to confirm.
I don't see why not. You could do a wet shot since it would go through the injectors, and I'm sure theres a way to rig up a plate system for a dry shot under the blower.
You should still confirm with Kenne Bell before you do that though. Don't want to screw up a several thousand dollar blower.
