Installing X-pipe~Need help
Every how to post I have came across so far says that I will need extensions to get to the passenger side head bolt. I am a little confused by this, can some one post pics or a list of the exact size/amount of extensions I will need. Also is there any other special tools I will need for the job? Thanks to all that reply!
The specs-2000 gt 5spd.
RE: Installing X-pipe~Need help
you need a good sized extension (dont know exactly how long...but its a good ways up there so if you got a couple extensions you can snap together that works too...about 2 feet of extensions is good)
a swivel head
and i believe its a 15mm socket
pb blaster on the bolts can make it a little easier to break them...they can be a pain to break the first time.
then whatever the catback bolts are.
a swivel head
yea when i did my off road x.. we used atleast 2 feet of extensions.. deff need a swivel its at a wierd angle... and patients dont give up on it if its aggrivating.... and if u dont have a catback yet and ur doing what i did till i ordered my catback it doesnt really sound good at all on stock mufflers.. lol
when you get under there you will see what we mean... i used a 3/8" drive 15mm deep socket (i recommend 6 point since some have had trouble getting it loose), 3/8" swivel, 6" 3/8" extension, 1/2" to 3/8" adapter, 6" 1/2" drive extension & a big 1/2" drive wrench. I had to step it down as 1/2" swivel would not fit in that space. I stepped it up to 1/2" further down the line so i could have the benefit of the big wrench. with soaking it for 1.5 hours prior to attempting to loosen the bolts, made it very easy. i broke them loose & got them the rest of the way off with my fingers. have fun!
ORIGINAL: chrismartintx
when you get under there you will see what we mean... i used a 3/8" drive 15mm deep socket (i recommend 6 point since some have had trouble getting it loose), 3/8" swivel, 6" 3/8" extension, 1/2" to 3/8" adapter, 6" 1/2" drive extension & a big 1/2" drive wrench. I had to step it down as 1/2" swivel would not fit in that space. I stepped it up to 1/2" further down the line so i could have the benefit of the big wrench. though with soaking it for 1.5 hours prior to attempting to loosen the bolts, made it very easy. i broke them loose & got them the rest of the way off with my fingers. have fun!
doesnt get any better then that
heh....i put my car up on the lift and looked at the passenger side bolts and said....FAK THAT! splurged $90 fora local mustang shop to install the X-pipe and MILS...
ORIGINAL: darcnytemare
