Weird re-starting issue.
So when I go to start my car for the first time of the day, it does just fine, no problem. But if I shut it off and don't let it cool all the way down, which usually takes an hour or two, it acts up. When I go to start it back up, it will stumble and then all the sudden fire up, but then it will idle at 2500 rpm until I put some miles on it, and then it settles down again. Has anybody else had this problem? It's driving me crazy.
RE: Weird re-starting issue.
Funny you mention it. My 99 used to do that too! Especially if I went for a short run, like to the store after it had sat for hours. Run into the store then back out and then I would have to crank longer or twice to get it to catch.
Dealership said there was nothing wrong with it.
Never did find the problem. Although I had someone tell me that it had to do with the fuel system and the car not burning off everything and the vapors being recollected or something like that. Maybe one of the more knowledgable people know what I am describing.
But it had to to with gas vapors and collecting them to reuse or something like that.
But then it could have been BS. I am an IT geek not as knowledgable about todays cars!
my car would run fine at start up but then if i stopped for gas or something and then went to fire the car back it up it would barely start and ide have to feather the gas for a few seconds to keep it running.... it was just the IAC, just cleaned it out with some carb cleaner and it ran just fine after that...probably all that was wrong on your 99
Ok, so I swapped my buddy's IAC with mine and it's still doing the same thing. If I posted a video showing what it does, do you guys think that would help any? Any ideas are appreciated.
