Porting upper intake plenum
Old Jan 22, 2008 | 11:07 PM
H0SS302's Avatar
H0SS302
Default Porting upper intake plenum
what do you need to do it? iv been thinking about swapping my 70mm accufab tb onto the stock plenum just becuase the pony is cool. if i could find a way to clean the pony up like new and maybe get the stock intake chromed or powdercoated gloss black, i think that would look neat.
so n e body got some knowlage on it?
i have heard you can do it with a dremel, but any advice would help.
thanks
Old Jan 22, 2008 | 11:16 PM
ninelives19821's Avatar
ninelives19821
Default RE: Porting upper intake plenum
I would see if you can get a air tool with a good burr bit on it, then when you get down to the finish work use a less aggessive burr with the dremel. Sounds like fun though im sure if you mess up you can get one for next to nothin at a junkyard *plenum that is*. I would sand the out side of it off real good to get it smooth and then polish it, that would look sweet!
Old Jan 22, 2008 | 11:18 PM
H0SS302's Avatar
H0SS302
ORIGINAL: ninelives19821
its a spare i have lol so it dosnt matter. i lack the compressor for air tools.. so the dremel is a must almost.
Old Jan 22, 2008 | 11:25 PM
timeformiller44's Avatar
timeformiller44
use sand while the motor is running....
Old Jan 23, 2008 | 12:57 AM
97targa's Avatar
97targa
I polished up my old plenum and it gets spotted up by moisture and foggy after a few weeks. You have to keep up on it all the time. Not really worth it. I would just take some Caliper paint to it since that paint is high temp and has ceramic coating in it for easy cleaning. I love the stuff. As far as keeping it because it looks nice....ehhhh, you can get a C&L plenum for fairly cheap and the airflow is improved a bit more than the stocker unit. That inside bend is a killer and there's no way to fix it except swapping it out with a diff one.
Old Jan 23, 2008 | 03:46 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
There's nothing you can do to a stock upper plenum to make it flow as well as an aftermarket unit. Here's accufab's flow data (1/2 way down the page for the new-edge), all the aftermarket units except C&L are 110+ cfm better.[/align][/align]This isdue to their being 3/4" or so higher which allows better internal contour at the"bend". The OEM plenum can be made marginally better by porting, however there's nothing that can be done to make it the same as even the worst of the aftermarket pieces.[/align]
Old Jan 23, 2008 | 07:26 AM
jrherald420's Avatar
jrherald420
just called my local engine builder yesterday about this it should cost 50-70 dollers to port match and fully smooth and polish the plenum. but mine is a professional products not stock..
97targa did you seal the newly polished plenum?????
Old Jan 23, 2008 | 07:37 AM
H0SS302's Avatar
H0SS302
ORIGINAL: cliffyk
There's nothing you can do to a stock upper plenum to make it flow as well as an aftermarket unit. Here's accufab's flow data (1/2 way down the page for the new-edge), all the aftermarket units except C&L are 110+ cfm better.[/align] [/align]This is due to their being 3/4" or so higher which allows better internal contour at the "bend". The OEM plenum can be made marginally better by porting, however there's nothing that can be done to make it the same as even the worst of the aftermarket pieces.[/align]
well what about an intake spacer. if i port match to my 70mm tb, wouldnt an intake spacer give it that extra room cliff?
Old Jan 23, 2008 | 02:19 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
ORIGINAL: H0SS302
ORIGINAL: cliffyk
[/align][/align]Not really as the sweep of OEM elbow is still going to be constrained by the physical size of the casting--this is why porting the stock plenum can't accomplish what an aftermarket unit can. Thephysically bigger dimensions of 3rd party castings provide internal space for a much larger and better flowing "elbow". [/align][/align]If you study the flow data, andunderstand that the most air a 4.6L engine can possibly move at 6500 rpm is 528 cfm (that's at an unattainable 100% VE, at 90% VE [still arguably high for a 2V motor]475 cfm is the max needed) then you can see that the OEM TB and plenum are OK up to 90% WOT or so.[/align][/align]It's only that last 10% where there is any need for better flow. This is why just slapping a TB and plenum on the 4.6 2V does not create any miracles. It does make the immediate response better, and can with a good tune give you 10 to 15HP+ in the mid-range, however peak HP does not benefit a whole lot.[/align][/align][/align]I am curious as to why are you going through all of this instead of just buying an aftermarket plenum ($90 to $120 on eBay)? [/align][/align]Is it just the pony orone of those"just to see if I can" sorts of thing (Lord knows I;ve done my share of those)?[/align][/align][/align][/align]
Old Jan 24, 2008 | 01:02 AM
H0SS302's Avatar
H0SS302
ORIGINAL: cliffyk
ORIGINAL: H0SS302
ORIGINAL: cliffyk
[/align] [/align]Not really as the sweep of OEM elbow is still going to be constrained by the physical size of the casting--this is why porting the stock plenum can't accomplish what an aftermarket unit can. The physically bigger dimensions of 3rd party castings provide internal space for a much larger and better flowing "elbow". [/align] [/align]If you study the flow data, and understand that the most air a 4.6L engine can possibly move at 6500 rpm is 528 cfm (that's at an unattainable 100% VE, at 90% VE [still arguably high for a 2V motor] 475 cfm is the max needed) then you can see that the OEM TB and plenum are OK up to 90% WOT or so.[/align] [/align]It's only that last 10% where there is any need for better flow. This is why just slapping a TB and plenum on the 4.6 2V does not create any miracles. It does make the immediate response better, and can with a good tune give you 10 to 15HP+ in the mid-range, however peak HP does not benefit a whole lot.[/align] [/align] [/align]I am curious as to why are you going through all of this instead of just buying an aftermarket plenum ($90 to $120 on eBay)? [/align] [/align]Is it just the pony or one of those "just to see if I can" sorts of thing (Lord knows I;ve done my share of those)?[/align] [/align] [/align] [/align]
i actually have a 70mm accufab tb/plenum combo. but i have a perfectly good stock plenum here and a dremel. it would be a nice learner project if you will.
my plans are to powdercoat the plenum gloss black, and have the pony plaque shining on top. if there is not real difference in throttle response i think the powdercoated black plenum would look good with the performance red stb i have. i keep my engine bay VERY clean, so all the hoses are shining black along with fuse box and radiator cover. even the bottom of my hood is pretty spotless.
it is the throttle body that yeilds the throttle response right, the plenum doesnt really do all that much correct?
