Crate Engine
Old Feb 4, 2008 | 09:32 PM
1997Stang's Avatar
1997Stang
Default RE: Crate Engine
ORIGINAL: True Blue Racing
i was gonna say if you were going drag car i have a 560ci engine for sale. but for that i would go with http://www.tonisenterprises.com/faster5.0/ford308.html we just put it in out '95. It is a nice set up. plenty of power and then throw a 150shot on there for fun and you will be set.
Now if i get that from the website, am i going to need to basically change everything on my engine to make things fit, or will the stock parts bolt right up to that?
Old Feb 5, 2008 | 12:05 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
your still going to need the 94-95 k member to have that bolt up, but im telling you there is no replacement for displacement. if they have a 331, 347 i would run with that. it seems like a very solid build on that 308.
Old Feb 5, 2008 | 07:07 AM
1997Stang's Avatar
1997Stang
Would i need to get a new intake manifold and all of that type of stuff?
Old Feb 5, 2008 | 07:25 AM
True Blue Racing's Avatar
True Blue Racing
Its just a long block. you need intake, your chioce of fuel delivery(carb or fuel injection) we put and MSD ignition on it. and i think that was it
Old Feb 5, 2008 | 08:18 AM
USMCrebel's Avatar
USMCrebel
thinking about the LB, whats the CR on it?
Old Feb 5, 2008 | 09:15 AM
True Blue Racing
I cant remember. Im at work and all the paper work that came with the engine is in the poll barn at home.
Old Feb 5, 2008 | 12:40 PM
1997Stang's Avatar
1997Stang
Could you give me a list of all the other things i would need to buy if i bought the long block please? Im reall considering this.
Thanks,
Mike
Old Feb 5, 2008 | 12:42 PM
True Blue Racing
yeah i can. It might be later tonight or tomorrow morning before i can get it to you.
Old Feb 5, 2008 | 06:36 PM
1997Stang's Avatar
1997Stang
Thats fine. Thanks alot![sm=smiley20.gif]
Old Feb 5, 2008 | 08:05 PM
True Blue Racing
now when we did this swap it was in a '95 with a 5.0 so we had the headers, alternator, a/c, powersteering pump, and k-member ect... you might want to make sure the bell housing on your trans with bolt up to a 5.0 block.
We went with a carb on ours. so we needed: Carb(we went with a 500 holy double pumper), intake(we went with a victory jr.), MSD ignition, MSD distributor, new fuel lines(to carb), fuel pressure regulator. and i think that was it, if i think of anything else i will let you know. If you call and talk to the guy he does have additional components that he can ad to the motor.
