Rear control arm mounting bolts, what grade?
I'm getting Ford Racing upper control arms and it is recommended to get new bolts, well the arms don't come with them.
What grade of nuts and bolts do I need to replace the stock ones?
Or is there a place to get new control arm mounting hardware witout going through Ford?
Lynn
Lynn
Location: Where gunshots are more common than birds chirping
RE: Rear control arm mounting bolts, what grade?
I used Grade 8 hardware.Just went to the hardware shop with the bolt that came out of the control arms and matched up the lengths.
I'm not positive on the size, either 12mm or 14mm. either way get 10.9 stainless bolts.
get it at your local hardware store, ford wanted something like $12 a bolt last time i checked.
If you haven't ordered them i have a set of the Ford racing uppers new in box i want to get rid of cheap.
ORIGINAL: 35thAnni99GT
ORIGINAL: bigmoose15
Grade 8 bolts are SAE, so if you go that route the bolt won't be the correct size.
I had UPR stuff and the holes were different than the stock bolt sizes and the SAE stuff actually fit better.
just go up to TSC and get some grade 8. i think 7/16" fit. thats what i put in mine when i did them. if cost me like $5 for all the bolts nuts and washers
