Wierd Transmission Noises
RE: Wierd Transmission Noises
ORIGINAL: steeda_exhaust
UT - in doing a search i found there are 2 tsb's one for 99-03 and one for 04. i didnt know there were 2 different tsb's.
Silver, i cannot tell you what the whining noise is, but i know there are some people here who can.
i found the below in a post from Casper98gt
Then there is a TSB for the 2004 ONLY!
ISSUE:
Some 2004 Mustang vehicles, equipped with the TR3650 5 speed manual transmission, may exhibit a clash or grind noise when shifting from 1st to 2nd gear. There may also be a loss of 2nd gear.
ACTION:
Order and install a synchronizer kit. The kit includes a 2nd main shaft gear, 1-2 synchronizer assembly, 1-2 shift fork and rail, synchro rings and cones and a new transmission fluid and fill label. Refer to the following Service Procedure.
SERVICE PROCEDURE
NOTE: ALL COMPONENTS IN THE KIT ARE REVISED AND MUST BE REPLACED. DO NOT INTERCHANGE.
NOTE: REFER TO THE WORKSHOP MANUAL SECTION 308-03 TO AID IN THE FOLLOWING PROCEDURE.
Remove the transmission from the vehicle.
Disassemble the transmission assembly.
Remove and replace ALL parts that are included in the kit.
Clean oil from area 1" (26 mm) below the transmission fill plug and install the oil fill sticker included in the kit (Figure 1).
Reinstall the transmission.
Fill the transmission with 6.3 pints (3.0L) of Motorcraft MerconĀ® Multi-Purpose ATF (XT-2-QDX). The new full fill level is approximately 0.75" (19 mm) below the fill hole.
Figure 1 - Article 04-26-13
PART NUMBER PART NAME
3R3Z-7124-BC Synchronizer Kit
XT-2-QDX Motorcraft MerconĀ® Multi-Purpose ATF
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
042613A 2004 Mustang: Install Components Included In Kit (Includes Time To Remove And Install Transmission And Final Road Test) 5.6 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
7124 42
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
7124 42
Dude. just so you know that TSB is for ALL 4.6 stangs with the 3650.....some 2002s and up.
They are doing it for the SECOND time on my 03 right now.
The second time? Was it right and then went bad again? How many miles on the fix? Mine is great so far...but only 600 miles since serviced. Ya got me a little worried now.........[sm=dontgetit.gif]
ORIGINAL: snlpa
1st, 2nd and 5th are good....4th has a bit of a rattle above 4500 RPM but 3rd is still all fuggered up. It's really bad. I think that's where the rattle in 4th is coming from.
When I had it done the first time, about a month ago, I also had the FRPP racing clutch and flywheel kit put in at the same time and a new release bearing.....just for the hell of it.
They figure I got a bad kit because it's only 3rd that still has a problem......Apparently, some of the kits still got a bad third gear and there is a new, more complete kit or some bullshiz.
I think there's more of a problem with my trans than just a minor rebuild will fix......It's kinda wierd because my driveshaft has more weights on it than I have ever seen.
I told them to do the pilot bearing while they are in there this time too.....just for kicks [8D]
Well I think that I will probally take it in but im also wondering if the whinding noise could be looked at I am not sure that mine is the only one that makes the noise. Can some one tell me if there trans. ever makes a whining noise while acelerating. Some one that has had the rebuild can they please tell me if it took long and did they fix it right. Cause I feel like the slowest that I put the stick in second it still seems to be a little bumpy and sometimes it dont even go in all the way it feels like it went half way and stoped.
KingRando
10-02-2015 08:06 AM
