stall converter
RE: stall converter
a stall converter is probably only a couple hundred bucks (i don't know for sure cause i've never had to buy one for a Mustang). the thing about driving in town... when you take off from a red light, your engine will rev up to a higher rpm than it would have with the stock converter, so it may get annoying seeing your engine rev up to 3500 rpm every time you take off from a red light or stop sign. if you don't do a whole lot of stop and go then it won't be as much of an issue.
RE: stall converter
Stick with a 2500 - 2800 stall and you will not notice much (100-750rpms)of an rpm increase when taking off. converter is going to run you about$300-500 and you can buy a trans cooler for about $40.
RE: stall converter
ORIGINAL: Stangatic
RE: stall converter
ORIGINAL: sleeping stallion
what is the best stall converter for my 02 gt with mods down below. what brand what size and so on.
RE: stall converter
You guys who are comparing your old cars without a lockup converter are giving poor advice in this thread. It's a totally new ball game with newer cars. BTW I run a 4000 Yank in my car and can take off pretty normal in it. To the OP,look into Precision Industries for a good converter, you will spend $6-800 but it's very worth it. TCI, B&M and the like are pretty much junk and a waist of money.
RE: stall converter
ORIGINAL: JD1969
RE: stall converter
ORIGINAL: JD1969
RE: stall converter
Because your leading people to think that theyare a close comparison, and they really are not.. No they don't lock up at just off idle (although it is possible to program the ECU to do it). Like I said my 4000 takes off pretty normal, unless you get in the gas really hard. I have owned plenty of old school and newer muscle cars, not to mention I have worked in the hot rod/performance car industry for years. These newer converters are a different animal. Do I reccomend a 4000 for a true daily driver? No, but I would not bother with anything less than a 3-3200 rpm unit, otherwise he will just want more down the road and will have waisted a bunch of $$. FWIW many companies will offer a free (one time), or low cost restall incase you change the setup or whatever.
