Help engine bogging out
Old Feb 16, 2008 | 09:49 AM
blowngt2419's Avatar
blowngt2419
Default Help engine bogging out
Hey guys i need ur help. I drive a 2000 mustang gt automatic and every so often i go to hit the pedal my rpm's fly to 1500 but then slowly move from there and then i can;t hear the exhaust anymore and then it just bogs would this be a fuel delivery problem or a ****ty tune because im supercharged and intercooled and my tune is just ****? Im running 42lb injectors and a new maf but all my friends are telling me its either fuel delivery or a ****ty tune? PLz help
Old Feb 16, 2008 | 12:59 PM
Obsequious1's Avatar
Obsequious1
Default RE: Help engine bogging out
I have a procharger 10psi on my 03 gt and every now and then while I'm driving when I punch the gas there is nothing for like a second then it responds. It never did it stock. Its nothing I'm worried about. Do you have gauges like boost and fuel pressure.
Old Feb 16, 2008 | 01:04 PM
Obsequious1
What type of sc do you have and do you know if the fuel pump has been upgraded.
Old Feb 16, 2008 | 01:06 PM
Pauly_B's Avatar
Pauly_B
ORIGINAL: Obsequious1
Are u running 10 PSI on a stock bottom end? if so any troubles?
Old Feb 16, 2008 | 01:30 PM
Obsequious1
I've been running 10 psi intercooled on a stock bottom end for over a year now. My only trouble is trying not to break my 315/35/17's loose in 3rd gear.
Old Feb 16, 2008 | 01:35 PM
Pauly_B's Avatar
Pauly_B
well maybe there will be a pulley upgrade in the near future.
Old Feb 16, 2008 | 01:41 PM
Obsequious1
I had my car dyno tuned, to be "safe", I left it @ 380rwhp 375rwtq. I was told I had more to go but I was worried about my STOCK bottom end.
Old Feb 16, 2008 | 01:48 PM
Pauly_B's Avatar
Pauly_B
tricky stuff dude. maybe i will leave it where it is for now planing on a rebuild in the next year or so after that well we will see.
Old Feb 16, 2008 | 01:51 PM
blowngt2419
im running a paxton novi 2000 on 8lbs of boost but i think im running a stock fuel pump and also it doesn't like bog then quickly respond like a hesitation it will stay bogged untill i shift back down
Old Feb 16, 2008 | 01:52 PM
blowngt2419
im also getting the gauges afr and boost and fuel pressure soon so when those are installed that would probably be a big help
