Kick Panel Removal
Old Feb 16, 2008 | 12:37 PM
NaughtyGeek's Avatar
NaughtyGeek
Default Kick Panel Removal
OK, now I feel like a complete idiot. I cannot get the plastic holder out of the kick panel so I can check for a chip in my PCM. I'm about ready to just cut it but thought I'd see if anyone here knows an easy way to get it out without destroying it.
Old Feb 16, 2008 | 12:44 PM
tbirdscwd's Avatar
tbirdscwd
Default RE: Kick Panel Removal
First you have to take off the little plastic running board cover (or whatever ist called). Then remove the plastic plugs that hold the kick panel on, I think there's one or two. Then pull the panel straight back towards the rear of the car. It should pop off without too much hassle, but if your pulling it to the side, your probably gonna break something.
Old Feb 16, 2008 | 12:46 PM
NaughtyGeek
Yeah, it's the plastic plug I can't get off. I've got the kick panel completely free other than the dang plug.
Old Feb 16, 2008 | 12:56 PM
tbirdscwd's Avatar
tbirdscwd
Can you get anything under the edge of the plug? Sometimes it takes a little persuation to get off. Try using an open ended wrench to pry it out. Avoid using a flathead if possible to prevent scratching your plastic. Or if you can get your fingers underneath the plastic and behind the head of the plug as support, you can pull on the whole kick panel.
Old Feb 16, 2008 | 01:21 PM
NaughtyGeek
Thanks. I got it off. I just had to get REAL persuasive about it. Unfortunately, I scratched the dang panel.[:@]
Old Feb 16, 2008 | 01:50 PM
Pauly_B's Avatar
Pauly_B
crapy
Old Feb 16, 2008 | 03:38 PM
tbirdscwd's Avatar
tbirdscwd
ORIGINAL: NaughtyGeek
Well good and bad. But at least its a kick panel and not a hood! I wouldn't worry about it too much. Glad you got it off though.
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Explosive
Oct 2, 2015 07:45 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
