what spline count do I have?
Ok so i mlooking for a clutch and want to get the DF from Centerforce. I am confused about which spline count i have because some websites say the 26 spline will work for my car and other sites say that its the 10 spline. I have a 2003 GT with the 3650 tranny..thanks for the help
RE: what spline count do I have?
10 spline is stock 26 spline is a aftermarketheavy dutyreplacementinput shaft that is stronger.
The clutch spec's you need are, 11' Clutch Diameter, 10 Spline X 1-1/16' for a stock 3650 trans.
ORIGINAL: dennis_112
Whats the best place to buy one, can we geta discount from a place that sells centerforce. Also with a DF clutch is it suggested that your quadrant be changed. And would you have to run a adjustable cable.
I will definitely be adding a quadrant and a new pilot and throwout bearing. Also, Im lookin to do a billet steel flywheel and the centerforce one is way over 300 bucks, but brothers performance has there own brand in billet steel 6 bolt for 150 on sale. It says for early 1996-2000 mustangs, but im assuming a 6 bolt flywheel is a 6 bolt flywheel right?
ORIGINAL: 03greyGT
REPLACE YOUR TOB RETAINER, I didnt and now its squeels like a stuck hog[:@]
also while your in there you could upgrade to the 26spline if you want/need to
