01 cobra heads will they fit on a 02 GT
my dad is buying a engine on ebay o1 cobra. he wants the 32 valve heads will they fit on his 02 GT.
the guy says this
Hello here is a complete 4.6 32 valve 2001 Cobra engine.I came from a friends car that broke a rod and damaged the block and crank.It still has a lot of good parts
the guy says this
RE: 01 cobra heads will they fit on a 02 GT
I'm sure it's possible, but no way that it's worth the trouble. Cobra has 4 valves, the GT only has 2. Tell your dad to stay away unless he wants to do an entire 4V engine swap in which case he would also have to obtain a knew block and crank. He would also probably want to upgrade to a minimum T-56 tranny and a really long list of other stuff.
some fabrication of the block must be done too i think. its not worth it to try to bolt 4v heads on a 2v block the bolt holes arent even in the same spot which is what i think the fabrication was for.
just buy a working 4v and call it a day.
11-10-2015 11:39 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
