HELP ME! Loud noise from rear!
Took the car for a spin this afternoon, it was fine. But when i took my gf home tonight there was a loud pitch whine noise coming from the rear of the car. It sounds like if you were to turn your ignition on and you hear the fuel pump noise, but it doesn't go away. The car smells like raw fuel, could be the exhaust leak, i know thats gotta get fixed. The only codes the car is throwing is rear 02's(p0136, p0156) I think my mils are bad though so i don't think that has anything to do with this, not sure. The noise is definetly louder outside of the car and even louder when you are at the rear abd bend down. Fuel pump is going bad? Really not sure what to think have never heard this before. Starting to get a lil scared.
RE: HELP ME! Loud noise from rear!
Thats what i thought right away and what my dad said but idk. It sucks tommorow i am gonna jack the rear up and hop under there and take a look around see if i can pin point the sound but im beggining to think its the fuel pump.
I would try a fuel filter first because its about $8 and it would more than likely fix it, butwhile the car is making the noise bump the tank to be sure that it is in the tank you will hear a difference in the noise. If the fuel filter dont fix all i can say is run it low on gas and put a fuel pump in it.
Ugg the fuel filter is brand new changed 1k miles ago, but i guess i can give it a try. Its almost like a siron like noise. Kind of flickering in and out. And when you press the brake it effects the noise.
Well If the fuel filter isnt that old i wouldnt replace it i know that a lot of people hardly ever change them, Have you bumped the tank to see if the noise changes. i think the noise would change because the brakes work off the power steering pump and it puts a load on the engine when you mash them on turn the steering wheel. Is the car running good other than the noise.
Just ran outside turned the car on, tapped the brake, noise goes deep, no brake noise is high pitched. Then i hopped under the car and the noise is definetly coming from the passenger side, bottom corner of the fuel tank. I'm almost positive its the fuel pump.
ORIGINAL: StangEatsRice
you gotta get under the rear, drop the tank, pull out the whole assebly, disconnect the wire,pull off the filter and change that, then pull out the fuel pump (if you need a pic just got to google or cjponyparts.com), replace it. when you put the fuel tank back in you will need someone to help you.
