TECH HELP PLEZZZ I changed my o2's and still have bad o2 codes ANY IDEAS.....BAD PCM? list of codes
http://www.paladinmicro.com/PalMFram...&dtc=P1130 -code list
today i got some new bosh o2s for my front banks i put them in and itstill says i havebad o2s in the front banks.the back ones are shut off...
(what happens when you disable your egr, without haveing the delete kit?)
Problem-little miss here and here at idle(sometimes I start it and it runs smooth and sometimes with a miss NOT sure if this helps but its more problems im trying to fix.
all this was like this when i got the car
codes
1000
0443
1451
0135
0155
1401
1409
i know what all the codes are
leading to bad pcm?
the mmotor is supose to be a 99 crown vic motor,ALL i know is the motor was changed and was told the check engine light came on when the cats where removed.
what are my chances of messing my buddies pcm up trying itout in mine? his 02gt
codes
1000
0443
1451
0135
0155
1401
1409
leading to bad pcm?
Codes dont always mean bad parts. You can swap out new parts forever and never fix it. You need a good scanner and someone who knows how to use it. Usually when removeing cats if you have four O2 sencors you will get codes. I did not look up your codes but most likely you wont fix this over a bulliton board. Find a friend with a scanner and did in and compare your readingsd to known good car.
TfcCDR
Sep 14, 2015 12:08 PM
