2v to a 4v question
Old Mar 22, 2008 | 11:59 PM
shigmonty's Avatar
shigmonty
Default 2v to a 4v question
I currently have a 2v motor and i want a 4v. could i just get some 4v heads and install them? if so how will this effect the computer, and could it be fixed with a tuner?
Old Mar 23, 2008 | 12:29 AM
silverstang1996's Avatar
silverstang1996
Default RE: 2v to a 4v question
it's a lot more work than just getting heads. best bet is to buy a complete engine or just a cobra/mach1
Old Mar 23, 2008 | 01:02 AM
Darkcrime's Avatar
Darkcrime
ORIGINAL: silverstang1996
+1 not worth the hastle. Plus, I believe the cobra/mach1 block is stronger than the gt's correct?
Old Mar 23, 2008 | 01:20 AM
trickdriller's Avatar
trickdriller
Nope, can't do it. That's the esiest answer I can give you because if you start to try, you will end up spending more than a brand new, fully-built shortblock costs.
Old Mar 23, 2008 | 05:33 AM
MU71L4710N's Avatar
MU71L4710N
2v is a cast iron block, 4v are aluminum blocks. tolerances i dont know (easily more than the internals) but as said...theres alot of fabrication involved in this. if it was just bolting on 4v heads...theres probably no one here that wouldnt have it by now.
Old Mar 23, 2008 | 10:27 AM
Sxynerd's Avatar
Sxynerd
Yup you can do it EASY....[:@] Just pull your car apart and buy parts as needed. It should be any more than around 3,000. No worries though. It's an easy swap. Just flip flop[:@]
I'm not being serious. I'm grumpy and I hate these threads. Nothing personal.
Old Mar 23, 2008 | 10:35 AM
N3TD3V!L's Avatar
N3TD3V!L
ORIGINAL: MU71L4710N
Thanks for the info. I had been wondering about a head swap myself and you just answered several questions I'd been wondering about.
Old Mar 23, 2008 | 11:15 AM
uberstang1's Avatar
uberstang1
Chupacabra
Been there and done that, just get a whole 4v and drop it in, the 4v head swap isnt worth the hassle.
Old Mar 23, 2008 | 08:28 PM
shigmonty's Avatar
shigmonty
is it worth it mony wise? and is it possible? if not what about 3v heads?
Old Mar 23, 2008 | 09:29 PM
N3TD3V!L's Avatar
N3TD3V!L
ORIGINAL: shigmonty
Check this topic.
