King cobra clutch problem
Hey guy, I put the clutch on my 96 gt install was fine but when i pulled out of the drive way i noticed the clutch released as soon as i lifted my foot off the pedal do i need to buy the adjuster i need some help dont know whats going on
RE: King cobra clutch problem
I don't exactly understand what you mean. Do you mean the clutch catches close to the floor? That is probably just how the clutch is. If you don't like the way it is then you will have to buy the clutch quadrant and firewall adjuster.
Sorry about that ok what happens is this i push the pedal put it in 1st as soon as release the pedal the clutch engages right away 100 % before it wouldn't fully engage till maybe half but know it engages as soon as i release the pedal an inch the clutch engages i hope this explains my problem a little better
I know what you mean now. Every clutch is different. Try doing the self adjustments. Just put the car in first gear with the e brake on. Pull the clutch pedal up with your foot and then push it to the floor. Do this a few times. If that doesn't solve the problem then you will have to order the quadrant and adjuster.
I already did some thing like that by the gas pedal where the quadrant is thiers a plastic clip i pull it and pushed the clutch pedal down it stayed in place pumped the pedal couple of time and it clicked a couple of times but i noticed it adjusts itself to the last possible adjustment where the clicking happens but what i don't get is way i would need the quadrant and adjuster and do i need both or can i just buy the firewall adjuster thanks for the help
