Cheap Lowering Idea?
Old 04-07-2008, 09:04 PM
OBX03GT
OBX03GT's Avatar
Default Cheap Lowering Idea?
I have a idea of lowering my car. Im gonna pull my OEM springs and cut them, no heat just cut and grind probably 1 3/4 - 2". If it doesnt work well i guess i can find a OEM set of springs for cheap around here! LOL It will probably wear out my shocks pretty quick but im gonna see what the results are! What you guys think?
OBX03GT is offline
Old 04-07-2008, 09:16 PM
baino
baino's Avatar
Default RE: Cheap Lowering Idea?
the springs are ratedto handlethe proper weight and height from the factory. So yes you will probably wear outother components quicker and have poor ride quality.
baino is offline
Old 04-07-2008, 09:21 PM
OBX03GT
OBX03GT's Avatar
U think i should spend 200+ to get some springs and lower my ride or ya think i can pull it off and cut my springs and buy some performance shocks and see what happens?
OBX03GT is offline
Old 04-07-2008, 10:09 PM
Mjaga251
Mjaga251's Avatar
I'd say if your gonna end up spending the same amount of money in they end to get back to stock, you should do it the right way the first time! Lowering springs, struts, cc plates, etc...
Mjaga251 is offline
Old 04-07-2008, 10:33 PM
fobra570
fobra570's Avatar
i would try it and if u dont like it would just give u a excuse to do it right
fobra570 is offline
Old 04-07-2008, 10:37 PM
rossn
rossn's Avatar
I started with just the aftermarket lowering springs and it worked ok. I am going to replace the shocks/struts soon though.
rossn is offline
Old 04-08-2008, 01:40 AM
Mustang3GT07
Mustang3GT07's Avatar
Just do it the right way and buy some aftermarket ones. This way you wont have to do it over again and you know it will be done rite.
Mustang3GT07 is offline
Old 04-08-2008, 01:47 AM
H0SS302
H0SS302's Avatar
the springs are not progressive. you will be FINE cutting the stock springs. i would only cut 1 coil tho, you will need c/c plates and new s/s if you cut 2inches off like u want. remember when u lower that much its not just the s/s you effect, its the tires too. but again you will be fine cutting the stock springs.
H0SS302 is offline
Old 04-08-2008, 02:10 AM
HEAVYMETALMATT
HEAVYMETALMATT's Avatar
just go to autozone and get replacement springs fora 87-93 gt. use the 4 banger springs up front if you want better transfer.
HEAVYMETALMATT is offline
Old 04-08-2008, 08:30 AM
bjh061487
bjh061487's Avatar
i wouldn't cut. there are plenty of cheap spring that you can get that i will lower it and get better transfer AND not ruin the other parts of the car
bjh061487 is offline
Quick Reply: Cheap Lowering Idea?
