Window Mod?
OK.. I love the fact that with a quick hit of the switch, my driver side window goes down all the way. How can I add the same feature to the passenger side window? Can I just buy another 2 switches and replace the one on the driver and passenger door panels?Are there any realys that need to be wired in? Could it be an easy plug and play with the rigth stuff, or will there be any slicing and splicing involved?
With good weather geting closer it would be sweet to be able to hit a few switches right before droping the top
instead of having to hold them down.
I suppose it could be done, howver you'd have to reprogram the GEM (General Electronics Module) and do some re-wiring to do it.[/align][/align]The GEM runs all the toys...[/align][ul][*]warning chimes and warning lamps[*]one-touch down window[*]windshield washers and wipers[*]illuminated entry with keyless remote entry[*]interior lighting [/ul]
It sees the quick hit of the switch and sends the window down. [/align][/align]The passenger side switch is just not wired through the GEM, its just a plain ol' electro-mechanical system...[/align]
I saw somebody do something pretty interesting (and seems pretty simple). He took a door panel insert from a crank window, non-power lock SN-95 so it had no window switches. Cut a hole in it, and wired one switch to it. He ran power and ground from the passenger side window to the driver's side window switch. Thus, controlling both windows from one switch and having both windows as one touch down. The parts that suck is that the windows went down a little slower andobviously not being able to work only one window at a time.
I found this about the GEM. It looks like it has the wiring for a driver and passenger "door triger". Would those be the wires that I am looking for? If they are, I am figureing that I would need to take the wire from the switch going to the window motor and re-rout it so that it includes the GEM in its circuit.
Although I'm nowwondering if it might just be easier to take it to an alarm shop and see if they could do it.
FORD / MUSTANG / 2004
12volts
yellow & lt. green/purple
ignition harness
Starter
white/pink
ignition harness
Second Starter
N/A
Ignition
red/lt. green
ignition harness
Second Ignition
N/A
Third Ignition
N/A
Accessory
gray/yellow and red/black
ignition harness
Second Accessory
black/lt. green
ignition harness
Keysense
black/pink
ign harn, 26 pin plug, pin 9 at GEM
Notes: The GEM (Generic Electronic Module) is located above the driver kick panel.
Power Lock
lt. green
20 pin plug, pin 20 at GEM
Power Unlock
purple
20 pin plug, pin 18 at GEM
Lock Motor
red/white
5wi
20 pin plug, pin 9 at GEM
Unlock Motor
red/orange
5wi
20 pin plug, pin 7 at GEM
Parking Lights+
brown
26 pin plug, pin 7 at GEM
Parking Lights-
white/black
26 pin plug, pin 11 at GEM
Hazards
same as turn signals
Turn Signal(L)
lt grn/wht(F), lt grn/org(R)
steering column
Turn Signal(R)
wht/lt blu(F), org/lt blu(R)
steering column
Reverse Light
black/pink
26 pin plug, pin 20 at GEM
Door Trigger
yel/black (L), gray/red (R)
20P plg, pin 13 & 5 at GEM
Notes: Use yellow/black for the driver door trigger and gray/red for the passenger door. Use both wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information.
Dome Supervision
black/white
20 pin plug, pin 3 at GEM
Trunk/Hatch Pin
brown/white
12 pin plug, pin 3 at GEM
The hatch pin needs to be diode isolated from the GEM module. Refer to DirectFax document 1076 for wiring information.
Hood Pin
N/A
Trunk/Hatch Release
pink/lt. green
26 pin plug, pin 25 at GEM
Power Sliding Door
N/A
Factory Alarm Arm
arms on lock with door open
Factory Alarm Disarm
dk. green/purple
20 pin plug, pin 16 at GEM
Disarm No Unlock
see factory alarm disarm
Tachometer
NOT red or white/lt. blue
ac
ignition coil or coil pack
Wait to start
N/A
Brake Wire
red/lt. green
brake pedal switch
Parking Brake
purple/yellow or lt. blu/blk
12 pin plug, pin 4 at GEM
Horn Trigger
yellow/lt. green
26 pin plug, pin 12 at GEM
Interface Module:
Category:
Immobilizer Bypass
Required:
Yes
Type:
PATS
Part #: 555FW
Alternate Part1 #: 556UW
12volts
ignition harness
Starter
white/pink
ignition harness
Second Starter
N/A
Ignition
red/lt. green
ignition harness
Second Ignition
N/A
Third Ignition
N/A
Accessory
ignition harness
Second Accessory
black/lt. green
ignition harness
Keysense
black/pink
Power Lock
lt. green
Power Unlock
purple
Lock Motor
red/white
5wi
Unlock Motor
red/orange
5wi
Parking Lights+
brown
Parking Lights-
white/black
Hazards
Turn Signal(L)
steering column
Turn Signal(R)
steering column
Reverse Light
black/pink
Door Trigger
Dome Supervision
black/white
Trunk/Hatch Pin
brown/white
Hood Pin
N/A
Trunk/Hatch Release
pink/lt. green
Power Sliding Door
N/A
Factory Alarm Arm
dk. green/purple
Disarm No Unlock
Tachometer
ac
Wait to start
N/A
Brake Wire
red/lt. green
brake pedal switch
Parking Brake
Horn Trigger
yellow/lt. green
Interface Module:
Category:
Immobilizer Bypass
Required:
Yes
Type:
PATS
Part #: 555FW
