do i need wheel spacers?
ok, the offset on the new edge is +24mm for the front and +22mm for the back. For the S197 its +30mm for front and +40mm for the back. These are 18x9 and 18x10 rims. Do i need wheel spacers?? can i get away with no getting longer studs??
no, they were 1500 brand new, im getting them for $380, so im sure u'd do the same. I just call Cruizin concepts and they told me they will fit perfectly with no problems?
just test fit them if you can, then youll know if they work.if the manufacture said theyfit, they you should be ok.if you were going to install longer studs, you have to hammer them out of the hub. i sure those wheels are going to look great on your ride though.
i can't test fit them, the guy im getting them from lives far and is doing a curbside delivery. But i know there is members on here that have done this, and i can't get an answer from anyone, i've had this thread open for over 2 months.
