Engine question
Old Apr 18, 2005 | 09:54 PM
The02GT's Avatar
The02GT
Default Engine question
What is the difference between the 96 4.6L and the 02 4.6L, is it the same block but different heads?? The reason i am asking is because someone is selling a 96 4.6L motor w/o acc. for cheap and i want to get it and build it over time and out it in my gt later on, will his work ok??
Old Apr 19, 2005 | 01:00 AM
The02GT's Avatar
The02GT
Default RE: Engine question
Anyone??
Old Apr 19, 2005 | 01:19 AM
97STANG's Avatar
97STANG
yah, heads, intake manifold, i believe the 99+ have bolt on cam gears as to pressed on, ignition system- the 96-98 have coil packs, the 99+ have coil on plug, i don't know if a 99+ cpu would run a 96-98 motor. can't really think of too much more.....hmmm. That would be pretty trick though to do the swap.
Old Apr 19, 2005 | 02:49 AM
The02GT's Avatar
The02GT
well is the block (pistons and rods too) all the same i dont care about the heads, i want to build the block and use MY heads, would that work??
GimpyHSHS
Aug 29, 2015 06:30 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
