power window adjustment
Old 04-25-2008, 08:52 AM
jjandascog
jjandascog's Avatar
Default power window adjustment
My drivers window rolls up a little to far, it rubs the roof trim just a little. I have seen posts about an adjustment screw on the regulator (?) to adjust the height of the window. Does anybody have a good pic or description of where this screw is, need to adjust the window about 2 RCH's down.
jjandascog is offline
Old 04-27-2008, 12:24 PM
jjandascog
jjandascog's Avatar
Default RE: power window adjustment
Bump?
Old 04-27-2008, 04:42 PM
pete1665
pete1665's Avatar
there are actually 2 adjusters in the form of 'L' brackets. They are located at the very top/inside portion of the door rather than on the regulator. All the brackets do is hit a metal tab attached to the window glass and stop it from moving up any farther. It is also common for the glass to come loose from where it attaches to the regulator arm so you may want to check that as well.This is all a little hard to describe but once you take off the door panel and the plastic sheet behind it, you will see what i am talking about inside the door.
pete1665 is offline
Old 04-27-2008, 04:49 PM
pete1665
pete1665's Avatar
errr..... my bad. actually the brackets are located about half-way down the door on the inside. The brackets at the top wont help your situaton. One of them is a bit hard to see but you will find the bolt and can probably reach your hand inside the door to do the adjustment. Good luck!
pete1665 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
DreadPirateRoberts
09-26-2015 02:11 PM
Pyrate Dave
09-10-2015 07:30 PM
DoctorScary
09-09-2015 07:53 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: power window adjustment
