Regular Maintenance
Old Apr 20, 2005 | 11:24 AM
jchittick's Avatar
jchittick
Default Regular Maintenance
My 2003 GT has 48,000 miles on it (owner before had a 120 mile highway daily commute). Is there any maintenance I should get done before I start modding it? (Tune up, spark plugs, any type of engine work?
[IMG]local://upfiles/13593/B162262977014C55BD8E0EB226447C50.jpg[/IMG]
Old Apr 20, 2005 | 12:43 PM
snlpa's Avatar
snlpa
Default RE: Regular Maintenance
I changed my spark plugs at 30k and the gaps were about .010 big from wear. So yea get those plugs changed. Also change all fluids if you have not.....rear diff, tranny..ect.
Old Apr 20, 2005 | 12:44 PM
Pacman's Avatar
Pacman
theres no time. start modding now!
Old Apr 20, 2005 | 12:46 PM
snlpa's Avatar
snlpa
ORIGINAL: Pacman
LoL...yea hurry!!!
Old Apr 20, 2005 | 01:31 PM
jchittick's Avatar
jchittick
ORIGINAL: snlpa
I've read a lot about the 4.6 and spark plugs. Easy enough for me to change with little engine knowledge?
[IMG]local://upfiles/13593/968CFB3A3FAE4C08A6AAB1CE1A707925.jpg[/IMG]
Old Apr 20, 2005 | 02:54 PM
Black_03GT's Avatar
Black_03GT
yes, they plugs are easy to change. i have an 03, and just did the plugs over te weekend. All you have to do, is loosen the little bolt on the coilpack (its a 7mm i beleive), then you can just pull it out from under the fuelrail, and remove it from the spark plug. I had to use 2 extensions to get out the plugs, but thats just because it made it easier. all you have to take off is the intake from the throttle body. just losen the tensioner screw and pull it off. Be careful on the back 2 plugs, as they are slanted, so make sure you dont get your ratchet stuck. MAKE SURE YOU DONT STRIP ANYTHING! I used NGK Coppers,and they are gapped to .054. All in alll, it took me a litttle over an hour to change all eight. Also, it makes it alot easier to work with the coilpaacks, if you remove the clip from theback of them before reinstalling them.
hope this helps
Excuse the typos, on a POS laptop
piotrek53
Oct 13, 2015 06:54 PM
mungodrums
Sep 29, 2015 09:18 PM
marc954
Sep 29, 2015 11:18 AM
Sep 25, 2015 06:42 PM
algregory
Sep 11, 2015 11:44 AM
