Coolant In Spark Plug Well = ?
Old 04-27-2008, 08:32 PM
MU71L4710N
MU71L4710N's Avatar
Default Coolant In Spark Plug Well = ?
Aight my buddy has had a misfiring problem. finally popped a CEL a while ago and it was a misfire in cyl 8. we finally got around to investigate it today and we were going to swap a cop over from my car onto his, and i checked inside his spark plug well before he stuck my cop in his (thankfully) and there was about 2 inches of coolant in it (the plug was completely under coolant).
we checked his oil, didnt see anything that looked like coolant in his oil...so i dont know if that would be a head gasket problem and i dont see how a head gasket would leak into the spark plug. he thinks his head is possibly cracked near the plug. i looked at his intake manifold and i didnt see any cracks near the cylinder, or any signs of coolant leaking out of it anywhere...but it was dark so i couldnt see very well anyways i'm gonna have to look at it again in the light.
what do you guys think? what is the most likely culprit here?
i was hoping it would just be a bad cop or a plug or something simple. we were working at almost dark so we didnt pull any of the other cops off the other 3 cylinders to see if maybe they had any either i highly doubt they do cuz the car would run much worse than ti does...if at all.
and i know the COP is most likely shot from bieng in that much coolant, and the plug is probably gone as well.
MU71L4710N is offline
Old 04-27-2008, 08:40 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
Default RE: Coolant In Spark Plug Chamber = ?
this happened to me...its the intake manifold...
mine cracked at the thermostat and leaked back and flooded cyl. 8 and it also flooded cyl. 5.... take a better look at the intake manifold, and if you have time, pull it out real quick and thoroughly inspect it... its only a 2 hour job to remove and re-install the manifold
and yes, my COP was roasted in both cylinders
99BlackPonyGT is offline
Old 04-27-2008, 09:37 PM
MU71L4710N
MU71L4710N's Avatar
yeah i had just gotten off the phone with my buddy whose already moved (he rebuilt several mustang engines tho). he said hes near certain its a manifold leak, which is my assumption as well since heads don't crack for no reason...and he didnt overheat.
i was already planning on pulling his manifold off this weekend, that was my guess having looked at the manifold. cuz theres an o-ring behind each of the 2 rear uhh...air inputs i guess that go into the head...and i wanna say antifreeze runs through there. if that o-ring went bad...or maybe even at the front by his thermostat then it could be leaking and we just can't see it.
i highly doubt its the head gasket cuz the AF would be in te cylinder...not the spark plug well. he's already pissed thinking its his head thats cracked and i'm still leaning toward something wrong with the manifold (either the manifold is jacked somewhere, or the o-ring that seals it is bad).
will update this weekend after i get it taken off (i had to change mine out right when i bought my car actually). any other suggestions please feel free to throw em out.
Old 04-27-2008, 10:11 PM
dimebag
dimebag's Avatar
get the heads pressure checked, its possible its the heads, and check out the intake... my guess is cracked head...
dimebag is offline
Old 04-27-2008, 11:25 PM
PhattyDre16
PhattyDre16's Avatar
couldn't it be a head gasket?
PhattyDre16 is offline
Old 04-28-2008, 09:01 AM
monkeydude3
monkeydude3's Avatar
I'd put more money on that intake.
monkeydude3 is offline
Old 04-28-2008, 09:05 AM
99BlackPonyGT
ORIGINAL: dimebag
you must not hang around us 4.6'ers too often.... our intakes crack more often than paris hilton gets rammed
Old 04-28-2008, 09:13 AM
monkeydude3
ORIGINAL: 99BlackPonyGT
ORIGINAL: dimebag
Ha!!!
Old 04-28-2008, 09:24 AM
1sloblckgt
1sloblckgt's Avatar
ORIGINAL: dimebag
Hahaha... That will be a sig...
1sloblckgt is offline
Old 04-28-2008, 10:53 AM
BlackMage
BlackMage's Avatar
ORIGINAL: dimebag
ahahahahaha love it!!!!
BlackMage is offline
Quick Reply: Coolant In Spark Plug Well = ?
