stupid keyless entry
Old May 1, 2008 | 03:48 PM
Topdog922's Avatar
Topdog922
Default stupid keyless entry
so my keyless entry decided one day not to work. so i put in a battery and that pretty much solved nothing. i amvery upset, any suggestions?
thanks
Old May 1, 2008 | 04:10 PM
97stanger's Avatar
97stanger
Default RE: stupid keyless entry
My keless is in the same boat. Some days i will have to sit outside of my car for like 3 mins trying to get it to disarm, and other days it will work. I also replaced the battery and nothing...im thinkin we may need to go to ford and just get a whole new remote...??
Old May 1, 2008 | 04:21 PM
Sxynerd's Avatar
Sxynerd
Whats the problem? Is it that the doors wont unlock or that the car shuts down after starting?
Old May 1, 2008 | 04:24 PM
1sloblckgt's Avatar
1sloblckgt
I think the OP is saying that his remote just stopped working... like the battery was dead and it wont lock or unlock the doors... correct?
Old May 1, 2008 | 04:45 PM
Sxynerd's Avatar
Sxynerd
If thats the case, then the remote may have moisture damage. Try taking it apart and use a pencil eraser to clean the circuit board and battery contacts for oxidation. If that doesn't work then the remote may be bad or the control module may be bad. (module would be in the driver kick panel or trunk)
Old May 1, 2008 | 04:49 PM
I G Joe's Avatar
I G Joe
in my remote one of the connectors to the unlock button is broken and the owner before me must have dunked the thing in cola because the unlock and lock buttons are all sticky so it makes them hard to press, i need to get a whole new remote.
Old May 1, 2008 | 04:53 PM
Sxynerd's Avatar
Sxynerd
Take it apart, pull out the battery. And use rubbing alcohol to get ride of the sticky.
Old May 1, 2008 | 05:26 PM
avlon06's Avatar
avlon06
ORIGINAL: sxynerd
you've got an asnwer for everything, its awesome! lol
Old May 1, 2008 | 06:19 PM
Topdog922's Avatar
Topdog922
ya it wont unlock or lock, wont open the trunk, and wont do the panic thing either. i took it all spart too the contacts are all good nice and clean. i know i didnt drop it in anything so that out.
Old May 1, 2008 | 06:23 PM
devongarver's Avatar
devongarver
check fuses in car. owners manual will show you.
