stupid keyless entry
RE: stupid keyless entry
haha what owners manuel mine didnt come with one when i bought it...ill figure it out though (fuse wise i mean) ill let you know 2morrow what i find on the fuses.
try programing the remotes. you will need both remotes when you do this becuase when you program the keyless entry iterase's all known remotes in memory. get in your car and shut the door. cycle the key from off to on about 6-8 times im not sure. , but you willknow its in program mode when the door locks cycle up and down. when it does this keep the key in the on position and press any button on the remote once. the horn should chirp if done correctly.once you have pressed a button on both the remotes. turn the key to off. and try the remotes. this should correct you problem as long as the remotes are good.
ORIGINAL: Topdog922
ya it wont unlock or lock, wont open the trunk, and wont do the panic thing either. i took it all spart too the contacts are all good nice and clean. i know i didnt drop it in anything so that out.
ORIGINAL: Topdog922
i only have one remote and key when i bought the car... then what? will reprogramming still work?
When you reprogram the remote thats all your reprograming; it has nothing to do with the key. I did fail to mention....like someone stated already, (i'm a failure) you could try reprograming your own remote before buying a new one. Google the reprogram sequence and give it a shot. That is, of course if your remote does not work at all. If it works, even a little or sometimes then it's not going to help reprograming cause it's just broke.
09-08-2015 11:50 AM
