fan running to much?
Hey guys, once my car gets up to operating temperature, the fan stays on. I know it should cool the fluid down and shut off, but it isn't. Once it's warm its on. I replaced the fan and sensor in the fan, didn't fix the problem. And no, my ACor defroster isn't on.Do you think itcould be my radiator? I noticed that the bracket that the radiator sits on is bent upward, which leads me to believe that the frontend had some damage previously. Any suggestions?
Location: Where gunshots are more common than birds chirping
RE: fan running to much?
If you're just cruising around or idling in traffic it should be on most/if not all the time on a hot day. If you're going down the highway is the only time it should really be off.
Yeah, it comes on even on a cool day, like 50 degrees. I can't really hear it going down the highway, but it's on when i stop from going down the highway. i think it runs too much!
If you really felt brave, you could wire the fan to a switch, so you can set it to run when you want it to since you seem to know the cars temp better than the car does[&:]
ORIGINAL: racersforford
well, anytime the ac is on or the defrost is on the fan should be on
So, if you have a handheld see when you activate the high/low speed fan settings. Other than that dude if it's not causing a problem and the only thing it's doing is turning on and off I don't see why it's a huge deal. I mean I know that your 4v heads have a tendency to drop valve seats out on because of cooling issues, so I don't see why you wouldn't want the fan on.
