Fuel filter location 03 GT
where is the fuel filter on my 03gt located, is it located inbetween the gas tank and the rear axle on the underside of the trunk? when replacing it how do i avoid fuel shooting out all over the place.
RE: Fuel filter location 03 GT
yea that's the write-up i used when i changed mine. just make sure u twist the top of the Shrader valve like it says to relieve the pressure in the fuel lines. some gas will still come out when u remove the filter so watch out (it won't be that much though).
if you're really worried about gas spilling out i think there is a fuse in the trunk that u can disconnect to turn off the fuel system. then u can just run the car 'til it dies.
and u don't need to disconnect the battery but if u feel more comfortable doing that then go ahead.
mrappe
09-26-2015 10:16 AM
