wow changed fuel filter
i have been having probs with skipping so i did a filter change... cheap and i have not done since purchase.... after the good gas came out there was dark reddish brown gas...... i wonder if the filter was factory.. all it says is made in tawaiin there was no in or out label on either side... car has 142K
today it was skipping so bad it would not move i had to pull over to let some ppl go by, cut car off and restarted it ran fine for a few more miles........no CEL yet
RE: wow changed fuel filter
I had a similar problem happen to me. It was embarrassing having an old couple pass me on the interstate and flip me off because my car was sputtering. Anyway, changed the fuel filter and ran like a champ.
ORIGINAL: timeformiller44
so did you change it?!?!
and 99.9% of the filters say which way the flow its...should be alil arrow.. i bought a nappa one and it said flow with an arrow
ORIGINAL: 02 Ninja
ORIGINAL: frizdank
So was it difficult to replace? Ive had a filter sitting in my garage for a few months cause i dont know how to replace it.
you will need a little plastic tool from the auto parts store to get the filter off though. i forgot what it's called but it should be on the tool aisle. it will say on the packaging "fuel filter removal tool" or something like that. shouldn't be too hard to find.
i changed mine with the help of my dad about a week ago. took us maybe 15 mins. the hardest part was trying to figure out how to get the OEM filter off
Yeah, I was wondering about that. I havent changed mine yet cause I heard that you needed a special tool to get the filter off. But did you need to relieve the presure in the fuel lines? You can do that by the cut off switch in the trunk right?
Sounds like your car isn't metering the fuel properly at the injectors. Although the filter may have a little affect, the reason the system is pressurized is that there is a back up of fuel waiting to go into the combustion chamber so the dirty filters effect is minimal unless its clogged.
I'd check your injectors, Maf, IAT sensor, and your plugs. Normally if your fuel pump goes out it wont work at all.
