need exhaust advice
Can any tell me if this set up would work. or wouldit have problems fitting together?
I want to start out with a set of bbk longtube headers. and the have a set of off road H pipes from flowtech with high flow cats added on later from pypes. and finaly a pair of afterburner muflers from flowtech. would i beable to use the bbk long tube headser with the flowtech off road h pipe?
any input will be much appreciated.
ORIGINAL: 99na
BBK headers are garbage, had to replace mine, I'd just go with flowtech if thats what the rest of the systems going to be.
ORIGINAL: 01KBGT
You have to use a mid pipe made specifically for the header. BBK Headers need BBK corresponding mid pipe. Every set of LT's are designed and sit differently.
ORIGINAL: shigmonty
thak you thats what i needed to know. so then i should just go with pypes headers LT's and h pipe right?
ORIGINAL: 01KBGT
Luke9222
Oct 22, 2015 11:55 PM
Sep 10, 2015 08:39 PM
