Traction/Power to the ground mods?
Old 05-09-2008, 10:48 AM
Trmachuno
Trmachuno's Avatar
Default Traction/Power to the ground mods?
If I plan to go f/i and see over 400rwhp, I'm gonna need a lot of help getting the power to the ground. What mods would help get traction with that kind of power besides the usual rear lower control arms, wider rims w/sticky tires, and thicker rear sway bar?
Thanks ahead of timefor any help.Decidingon future plans.
Trmachuno is offline
Old 05-09-2008, 10:51 AM
35thAnni99GT
35thAnni99GT's Avatar
Location: Where gunshots are more common than birds chirping
Default RE: Traction/Power to the ground mods?
subframes or a roll cage to reduce chassis flex. drag shocks/struts, airbags, springs all to help with weight transfer.
35thAnni99GT is offline
Old 05-09-2008, 10:56 AM
1999 GT
1999 GT's Avatar
get some good sticky tires and sub frames
1999 GT is offline
Old 05-09-2008, 11:11 AM
oxfordgt
oxfordgt's Avatar
All the suspension parts in my sig will work
oxfordgt is offline
Old 05-09-2008, 11:15 AM
oxfordgt
oxfordgt's Avatar
Oops I forgot there isnt enough room in the sig to fit everything.
Subframes, rear shock tower brace, relocate battery to the trunk, remove front swaybar.
oxfordgt is offline
Old 05-09-2008, 11:24 AM
35thAnni99GT
ORIGINAL: oxfordgt
I really want to do this, not only because it looks clean, but moving that 60#'s is supposed to help greatly. It just looks like alot of work.
What kind of short time improvements have you seen from it?
Old 05-10-2008, 02:24 PM
hot wheels
hot wheels's Avatar
not difficult at all, probably 40 min.
hot wheels is offline
Old 05-10-2008, 04:56 PM
oxfordgt
oxfordgt's Avatar
Took me about 30 min to install with the hardest part for me being finding a good spot to drill the holes. I probably have 13 holes under the box cause i kept going into a frame. I only had this problem because I have a rear strut tower brace. I'll try to get ahold of my friend who is taking care of my car for me and have him send a pic of the trunk. If you do the delete get rid of all the old battery wires I see alot of people keeping them in the car and even attaching the old red to the new then to the fuse box, ugly. And its not 60 lbs more like 20.
oxfordgt is offline
Old 05-11-2008, 12:30 AM
Burtonsnow157
Burtonsnow157's Avatar
an aluminum driveshaft shouldhelp you out a little bit. . . less parasitic loss on the drivetrain. . 11 pound loss or something like that. not crazy difference, but every bit helps.
Burtonsnow157 is offline
Old 05-11-2008, 12:49 AM
2000GT4.6
2000GT4.6's Avatar
My car hooks really well on the street, on the less than stellar 315 nittos. I can leave at 2k, and once the clutch is out pin the throttle with usually zero tire spin.
What I have done is:
Strange 10 way adj shocks/struts
subframes
upper/lower C/As
Fox 4cyl front springs
Roush racing rear springs
2000GT4.6 is offline
Quick Reply: Traction/Power to the ground mods?
