car died while coasting in neutral
well this is the second time this week, first time i thot it was my mistake becuz i have a lanyard on my key and maybe i accidently pulled it and turned the key off but didnt think so and tonight while coasting in neutral my car just shut off, not stutter or nothign just like if i shut my ignition off...started up perfect...i have a 5 spd...and dubarado (who i was following, we live 4 houses apart) said it was posted on here once and it happened wit a person with a 5spd...please help this could be dangerous!
RE: car died while coasting in neutral
and idk if this is related but recently every day on the first start it takes like 6-8 seconds of cranking to start it the engine, its never been like this, even in the winter it would crank 2-4 times not 6-10 like it is now
i had the same problem. i changed the iac, still did it. lo and behold i changed my tb/plenum back to stock and now it runs perfect. i saw you have an aftermarket75mm like i did. don't know if it's causing you the same problems but it's a thought.
If you were running your car hard then threw it into nuetral and it died, it might also be the fuel filter. Sounds lame but it happened to me. Found some bad petro i guess and she died twice on me, swapped it and had no prob. <cheapest to start with on your search
