Lt header problems....
Old May 15, 2008 | 07:23 PM
  #21
bluepony4.6's Avatar
bluepony4.6
Default RE: Lt header problems....
ORIGINAL: ripped camel
The code is the following:
P0153 - O2 circuit slow response bank 2 sensor 1
You get that codebecause it takes longer for the 02s to heat up. By the time they heat up to the right temperature the computer thinks that something is wrong and you get a code. Get a tuner to delay the time that your computer get the voltage reading from the O2 sensors. I have long tubes and I had that same problem. I used to start the car and just sit there with the RPMs around 1800 trying to get the 02 sensors up to temp quicker so I wouldn't get a code, however I would still get one when coming to a stop light (the computer still gets reading from the O2s). I took my tuner to Brian at Texas Hot Rods and he delayed the time for the computer to get the voltage reading from the 02s and I have not had that problem ever again.
I bought new 02s before I found out what the problem really was. It didn't make one bit of difference. So find out what chip you have, take it to a reputable tuner and get your front O2s delayed. You won't be sorry.
Old May 15, 2008 | 10:31 PM
  #22
ripped camel's Avatar
ripped camel
Can I delay it with a handheld tuner?
Old May 17, 2008 | 01:31 PM
  #23
bluepony4.6
Sorry for the delay in responding. No you can't delay them with a tuner. You have to get a shop with the software to do it.
Old May 17, 2008 | 03:53 PM
  #24
jwarner0297's Avatar
jwarner0297
So out of curiosity, do all LT's rub against the steering shaft?
Old May 17, 2008 | 09:13 PM
  #25
bluepony4.6
ORIGINAL: jwarner0297
Mine does. There's just not enough space in there.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
