96 tp 2001 Swap info
Old May 15, 2008 | 05:23 PM
lmcracing's Avatar
lmcracing
Default 96 tp 2001 Swap info
Its almost time to drop in my 2001 4.6 into the tired 1996's spot. My questions are:
Since the 2001 has no oil level sensor what do I do with the cable? cut or tie it off? Will this cause a check engine light?
Will the 2001 or 1996 Serp belt fit? I am using all the bolt on accesories from the 1996 with the exception of a 2001 alternator
Will the 1996 stock exhaust manifolds fit the newer block? (until I can get headers)
Thanks! I am trying to buy everything in advance for a smooth weekend swap
Old May 15, 2008 | 06:39 PM
Sxynerd's Avatar
Sxynerd
Default RE: 96 tp 2001 Swap info
Cut it off and no it wont cause a light.
The belt will fit. only accesory that Im not sure about is the tensioner.
Just use the 01 manifolds so you dont have to take them off. Yes the 96s will fit if you have to use them.
Old May 15, 2008 | 08:51 PM
RuffCat's Avatar
RuffCat
if your using your old ecu, you'll need to get it reprogrammed!
Old May 15, 2008 | 09:53 PM
lmcracing's Avatar
lmcracing
How do I get my ECU re-programmed? doI need a tuner? Can the car run on the stock 96 mapping until then?
Old May 15, 2008 | 11:27 PM
Sxynerd's Avatar
Sxynerd
Yes, it can run off the old ecu. You wont get the full gains till you get the 4v fuel maps and timing. You'll need to get a custom tune and not just a chip or hand held. Find a mustang shop in your area that tunes with SCT or Diablo.
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sixer4Life
Sep 29, 2015 07:03 PM
RCS02v6
Sep 29, 2015 01:46 PM
Sixer4Life
Sep 28, 2015 07:05 AM
