Rocker Arms FELL OFF!!! Help!!
#24
RE: Rocker Arms FELL OFF!!! Help!!
I chucked 2 of my rocker arms on a '88 LX with the 2.3L OHC I-4 by over-revving the thing. That would be my guess as to what happened. Put them back on and it will run but it probably will happen again. Youmay havewhacked the valve guides or something worse when you chucked them.
#25
Location: Where gunshots are more common than birds chirping
What weight oil are you running and now may be a good time to check out your oil pump/cooler assemblies if this isn't your DD.
#26
I agree, things look a bit dry and overheated back there--if the valves stuck then the followers could spit out; excessive float from over-revving might do that too...
#28
Running too thick of an oil too may cause lash pump up issues at high RPM's. A higher viscosity oil will pump the lash adjusters up under high RPM conditions to the point where it may cause an issue like your car is having.
Jus' Sayin.
Jus' Sayin.
#30
ORIGINAL: josh.davis
my car did thesame thing when i over revved the motor. I just threw them back on and it ran fine.
