remove engine
Old May 21, 2008 | 09:36 AM
gone to 7734's Avatar
gone to 7734
Default remove engine
Need some help please. 1996 mustang gt convertible I need to know where to hook the lifting chain to remove the engine. I'm leaving the transmission in place.I was told that the Intake must be removed but didn't wantto remove it from the new engine. I know this has been addressmore than once but I'm some whatnew to the site. Thank you for your advice.
Old May 21, 2008 | 09:57 AM
oxfordgt's Avatar
oxfordgt
Default RE: remove engine
If you don't remove the intake you will have to go to the ford dealer and order the engine brackets that you will have to loosen the header, install the bracket, tighten header then lift the engine. Plus they cost you around $100. Just take the intake off.
Old May 21, 2008 | 10:32 AM
gone to 7734
Thank you for the reply. I was hopeing there was another way.
Old May 21, 2008 | 02:30 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
+1. And taking off the intake manifold is easy enough anyway.
Old May 21, 2008 | 10:23 PM
bluepony4.6's Avatar
bluepony4.6
+1 Taking off the intake is easy.
Old May 22, 2008 | 03:53 AM
mcgilvrey007's Avatar
mcgilvrey007
hey yall, there is another way, just put a bolt in the back of the drivers side head, and one in the front of the passenger side head
[IMG]local://upfiles/72760/00411A8FBEB4413B9C869073612969DB.jpg[/IMG]
Old May 22, 2008 | 04:06 AM
oxfordgt's Avatar
oxfordgt
There is a very good chance of destroying the intake by using that back hole. Plus getting a bolt long enough with a chain in there with the firewall right there is gonna be near impossible. Plus I assume he is swapping in a PI motor and that rear hole has the bracket for the coolant line.
Old May 22, 2008 | 02:17 PM
bluepony4.6
ORIGINAL: oxfordgt
That is definitely the reason I took the intake off.
Granatelli Sales
Jan 20, 2020 12:34 AM
MusicCity615
Sep 27, 2015 12:53 AM
spamedic
Sep 9, 2015 12:15 AM
Gary Ugarek
Sep 5, 2015 09:03 PM
