rear end gear question
Old 05-26-2008, 03:05 PM
UmX
UmX's Avatar
Default rear end gear question
I bought my car used abotu 2 years ago.. i was told they had a 3.73 in it .. is there a way to check?
UmX is offline
Old 05-26-2008, 03:30 PM
AirBrontosaurus
AirBrontosaurus's Avatar
Default RE: rear end gear question
On the highway, drive at an even 60 mph and have someone (not you) record the RPMs (try to be accurate).
Then, plug it into this equation:
Gear Ratio = (RPM*Tire Diameter)/(MPH*336)
So, assuming a 25.7 in wheel diameter, and a ratio of 3.73, your RPMs should be about 3,000. If it's higher or lower, you know you're not at 3.73.
AirBrontosaurus is offline
Old 05-26-2008, 04:30 PM
UmX
UmX's Avatar
im guessing 5th gear ? since im a stick? tire dia in inchs to right?
UmX is offline
Old 05-26-2008, 04:42 PM
black35th
black35th's Avatar
or just check out this site made by the intelligent CliffyK
http://www.paladinmicro.com/PalMFrame00.htm?wks= Look on the left hand side for RPM vs. Speed, it should be all the way at the bottom.
black35th is offline
Old 05-26-2008, 05:05 PM
StriderTacticaL
StriderTacticaL's Avatar
I'm pretty sure with 3.73's your not gonna be at 3k at 60mph. I read somewhere that you'll be at like 2005rpm. Which kinda makes sense since the 3.73's are considered an all around choice and 3000 at 60mph sounds really too high to me lol
Brandon
StriderTacticaL is offline
Old 05-26-2008, 05:07 PM
jwarner0297
jwarner0297's Avatar
or you could put your back end on jack stands and with it in nuetral, mark driveshaft location and tire location (tape, chalk, etc.) then rotate the tire and count its revolutions in perspective to the driveshafts revolutions to be accurate you would have to spin the tire 100 times.
jwarner0297 is offline
Old 05-26-2008, 05:15 PM
black35th
black35th's Avatar
ORIGINAL: StriderTacticaL
Brandon
In 4th gear you would be around 3k. AirBrontosaurus forgot to mention that he needs to be in 4th gear at 60mph
Old 05-26-2008, 05:18 PM
UmX
UmX's Avatar
i went to that site.. at 50 in 4th im at 2500rpm on the dot, 50 in 5th at 1700rpm and at 80 im at 2700rpm. if u change out gears does it make the speedo off?
edited: 4th gear 60mph 3k rpms
UmX is offline
Old 05-26-2008, 06:19 PM
black35th
black35th's Avatar
Yes a gear change will make the speedo off unless it has been corrected by some sort of tune, but it sounds to me like your running 3.73's and that the speedo has been corrected either by a speedcal box or a chip with a tune on it, unless you have a handheld.
Old 05-26-2008, 06:59 PM
UmX
UmX's Avatar
no i dont.. i dont wat was done to this car before i got it.. all i know it had 24k miles on it.. had bbk cold air kit, bbk headers, bbk off road H, 40 series flows, the 3.73s and idk wat else has been done .. i was thinkin of getting a dyno and a tune..
UmX is offline
Quick Reply: rear end gear question
