Reverse Light problems!!
Old Jun 5, 2008 | 09:07 PM
Eminembdg's Avatar
Eminembdg
Default RE: Reverse Light problems!!
checked the grounds in the trunk, they are good. it's making contact yes, checked using my meter for continuitiy, tranny in neutral- no continuity , tranny in reverse-continuity, so it's making contact. I've been tryin to post the wire diagram but it's in pdf format, so it won't let me.
Old Jun 5, 2008 | 09:12 PM
lilc1511's Avatar
lilc1511
with your meter test the ground wire for continuity on the ohms setting. it should be low, less than 1ohm, prolly around .4... if you have that you know your ground is good. i know you checked the ground connection but that doesn't mean the wire is good. i HAVE to assume there is no power at the connector in the back. working your way back is a good idea. if you tested the switch activate it and then check your reverse lights.. then you will know if its the switch not activating like you asked above. find a wiring diagram, should make life easier.
sorry we posted at the same time.... i will look at the diagram.
Old Jun 5, 2008 | 09:17 PM
lilc1511's Avatar
lilc1511
sounds like you must have a bad wire somewhere then... or possibly a bad connection
Old Jun 5, 2008 | 09:22 PM
Eminembdg's Avatar
Eminembdg
yeah that's what I'm thinking now, goin to have to take out my driver seat to trace the wire easier. thanks for your guys help! will let ya know what happens.
Old Jun 5, 2008 | 09:24 PM
lilc1511's Avatar
lilc1511
wait!!!!
to make it a little easier on you.... if your meter has long enough cables just check continuity through the wires from the tranny back to the trunk. if your cables aren't long enough then you can extend the wire by using a jumper or something... that will at least give you a place to start.... instead of trying to work on back slowly..
Old Jun 5, 2008 | 09:30 PM
Eminembdg's Avatar
Eminembdg
what??? lol
Old Jun 5, 2008 | 09:43 PM
Eminembdg's Avatar
Eminembdg
omg the suspense is killing me! lol what you tell me to wait for?
Old Jun 5, 2008 | 09:45 PM
lilc1511's Avatar
lilc1511
sorry i thought you were going out to your car, then my dad called me and rambled forever... lol
i edited the above post, check it out, should save you some time.
Old Jun 5, 2008 | 09:47 PM
Eminembdg's Avatar
Eminembdg
ok, i can do that, thanks again! will keep ya updated
Old Jun 5, 2008 | 11:58 PM
CubanoGT's Avatar
CubanoGT
had the same problem lucky for me i got dealer warranty lol good luck bro because they told me it was kinda serious.. not simple bulb change..
