Procharger Help!
Alright i have a 2000 gt and a p1 2 core kit for it. I am finally getting started on installing it. Now i need help with injectors and mass air stuff. I figure i need 42's from what i see. But im not sure what mass air, fuel pump i need. so hear are some question i need help with.\
1. what mass air should i get for 42# injectors?
2. Fuel pump?
3. Ifi put this on a pretty stock motor would it need retuned everytime i put like a bolt on (throttle body) on?
4. What else do i need?
I really need help as this is my first time around with this stuff. so ANY help or advice you guys have would be so helpful. thanks- jordan
2. Fuel pump?
1. 90mm mass air off a ford lighting
2. not to sure
3. only if you did a cam install or nitrous
4. blower cams
p.s. give this thread some time b/c i know there are some procharger mustang on here.
2. not to sure
4. blower cams
depending on your goals.......How much Horsepower do you want?
if you want to roll around with 450whp or less.(and yes 450whp will most likely blow the stock motor, i belive it is what all the parts below go to About...)
[ul][*]42lb injectors, $300[*]SVT Focus Pump, $100[*]Lightning Mass air Meter $100[/ul]If you want 500-700whp range(same boat i am in Look at SIG) [ul][*]60lb Injectors $3-400[*]Cobra Tank & Pumps $300-900[*]hpx mass air system $300[*]built motor $$$$$$$2k-6k [/ul]
Dragonus18
Sep 9, 2015 01:21 AM
Black_GT_02
Aug 20, 2015 01:26 PM
