leaking headers
its on the connection of one of the exhaust ports to the main exhaust port...i believe it was already re welded... would a hardware store cold weld 2 part weld thing work??...better said on the weld marks on the connection of the main port. their shorties from jba
JB weld might work but I'm sure some kind of shop around you will fill the hole in withweld for a small amount of money like 20 dollars maybe. But thinking about it, JB weld is practically made for stuff like this I would try that first as well.
jb weld will not hold together at those temps, in fact theres nothing i know of thats available on the market thats meant to repair headers since they see such extreme temperatures. If i were you I would not use a product that can only withstand 500 F when your headers get hotter than that within minutes of running.
edit: to fix
either get it welded by a shop, good shop would charge 20-40$ at most, or send them back.
edit: to fix
bradleyb
Nov 27, 2015 07:50 PM
junior04
Sep 28, 2015 10:53 AM
