I did this install about 3 weeks ago and i have had too much crap going on to figure out what is wrong with this. it just seems like WAY too much strut shaft sticking through. It just looks ridiculous. what could have gone wrong? the suspension up front is 4cylinder fox springs, kyb agx adj. struts for fox bodies, steeda balljoints, steeda tie rods, and these cc plates. i don't have any clearance issues and the only problem i can notice is it seems like the front end isn't picking up like it should, as if the struts are maxed out. suggestions?
i feel better now that others have the same thing i have going on and that it is normal (hopefully). thanks. Here is a pic of how low it is. if you flatten out you hand then that is all that will fit in between the tire and wheel well.
