Suspension Questions
I have been thinking about upgrading my suspension some for better launches. I have LCA's I was thinking about subframe connectors. I have seen them from $50 on ebay up to $200. What are the differences? Also would a rear strut tower brace or and axle brace help?
RE: Suspension Questions
I would only recommend maximum motorsports, griggs or kenny brown for your subframe needs. Full length is the type you want. The difference in prices is mostly due to the material used and time spent research and design. When installing, make sure its a 4 post lift because the 2 post lifts will flex you chassis and cause the sfc to not line up correctly. Make sure the sfc fits without any bending as it is strong enough to bend the frame.
I have the Maximum Motorsports full-length subframe connectors installed on my 01 GT. They are top notch quality. I would highly recommend doing this mod as soon as you can. Its relatively inexpensive and it will make a world of difference in the way your car rides and handles.
09-08-2015 11:50 AM
