What size fuel injectors?
RE: What size fuel injectors?
injectors, check out rpmoutlet
as for my whp # ill get a pic posted of my dyno graph as soon as i can resize the photo
ported heads
cams
dss short block
p1sc (3.1' upper pulley)
lt tube,no cat x-pipe,slp lm2, alum flywheel, cl plenum,75mm tb,ect,ect
ported heads
cams
dss short block
They say that because they can if you increase the fuel pressure to 80psi. But you cant do it with a computer run returnless system.
You have EV1 style injectors in order to run EV6 (03 cobra) you need the adapters.
Ok, the 41lb and 62lb are ev1 which means i would just plug in so to speak.. but the 52lb are ev6 which means i would need the adapters.. ZW99GTsuggested that i put 60s inbut i think that would be over the top unless i am running 20psi which is max for the blower i have right now. I am thinkinking the 2.8 pulley would be around 15-16 psi which is doubling my boost, I have forged internals but i think 12 would be the highest i would go which is 3.00 or 2.85 i'm not really sure, what would be the best bet for a 12-13 psi setup?
ORIGINAL: AcidCobra
I don't know a whole lot about injectors. I get all my fuel from a solenoid.
crower stage III s/c cams. they lope like crazy. and yes im intercool ,most prochargers are. on a dynojet in phx, az (amp performance) in the middle of the summer. temp. was about 92F, so its real street number. i hate when people dyno their cars in an a/c warehouse where its about 70F and get big dyno numbers to make big claims. you always want to replicate the conditions the car is most likely to see on the road to get a more accurate tune.
the dyno thinks its a good cam. also, you can call or just check out their website,crower/crane/ comp cams on what cams they recommend for those hp #'s and all they will tell you that youll have a rough idle with any cam that makes power past 6300rpm with a blower.
ORIGINAL: pcs
Anyways, what heads are you using? What springs did you use? If my information is correct, thats a .612 lift cam, which is absolutely massive for these engines.
Lope at idle does not mean large LSA. That is only in a NA cam. A blower cam gets it lope for the duration. A stage 3 blower cam should only have around 530 lift. Blower cams dont need lift just duration.
OP what blower are you running.
